CODESYS Control for emPC-A/iMX6 Multicore SL
The CODESYS Control for emPC-A/iMX6 Multicore SL is an extension of the CODESYS Control for emPC-A/iMX6 SL, an adapted CODESYS Control runtime system for the real-time capable industrial controller emPC-A/iMX6 from Janz Tec AG.
