Search results for: 'can sl'
- can a 111
- can and 120
- can engine 100
- can+and 120
- can codesys 180
CODESYS Sensor App for Android 000073$0.00With the product “CODESYS Sensor App for Android”, the sensor data of from an Android smartphone can be sent to a CODESYS controller.
HVAC I/O Modbus Modules 2312000001$0.00The library allows the use of HVAC Modbus I/O modules of the manufacturer powerIO via a RS485 COM port. The devices are appended in the project tree and are parameterized from there without further programming effort. In the I/O Mapping area the assignments of the input/output variables can be set. The modules are available with emergency manual operation level and without. The status of the manual override is queried.
